Status Graphics not working for ranges
    Hi All,
    Has anybody else seen this?
    I've setup status graphics some as single values, some as ranges.
    When the device value is equal to a single value graphic, the label shows up correctly in the status
    When the device value is in one of the rnages, the label does not show up only the value in the status (see screenshot below)
    Have I missed something obvious?
    I have had similar issues with hs responding to my status/graphic setup. So unless you have seem this accomplished elsewhere, i think you are push the limit/capability of the HS engine. I would email rich directly to see if your approach is supported.
    Mark
    HS3 Pro 3.0.0.534
      Thanks mnsandler . Will try raise a ticket but then will look at emailing Rich.
      Checked all my code a few times and couldn't figure out any mistake.
      I'm trying to resist creating 99 status graphic values 😌
        I think it should be supported, but also using the status under Edit status/controls is not working. I reported a issue that for a device it could not be set that it is a status only device.
        Maybe I should also report this.
        John
