So, if you have a plugin that has created HS3 devices and is running in both HS3 and HS4, how are you going about converting those devices to HS4?
Are you creating new HS4 devices and somehow maintaining the reference numbers so the events do not get borked?
I'm thinking of a startup process that:
- Get a list of all my plugin's HS3 devices (using the old Scheduler.Classes.DeviceClass)
- Create corresponding HS4 devices (using the new HSDevice class)
- Delete the HS3 device
- Change the HS4 device reference number (is this even possible?)
