How do I get device string with ScaleText for current value?
    I have features with ScaleText, how can I get the current device string?
    Both EProperty.Status and hsDevice.Status return empty string. Do I have to manually convert current device value to string?
    spud ?
    I do this, but it's so ugly - I hope there's better way?
    double v = (double)ValueCached;
    StatusGraphic sg = GetStatusGraphic(v);
    StatusControl sc = GetStatusControl(v);
    var ad = AdditionalStatusData?.ToArray();
    s = sg?.GetLabelForValue(v, ad) ?? sc?.GetLabelForValue(v, ad);
      Basically what you want is a replacement for CAPIGetStatus() that we had in the HS3 API, correct?
      If so, I don't think it exists in the HS4 Plugin SDK yet
        I just want to read current device string (EProperty.Status) which was not set directly, but via the device value with ScaleText, i.e. if the device displays "-33.794702°" - but EProperty.Status returns empty string.
        Possibly it's a bug? Is it supposed to return "-33.794702°"?
        [EDIT]
        Yes, this workaround works:
        var capi = HS3.CAPIGetStatus(RefId);
        return capi?.Status;
          Status Eproperty in HS4 is the HS3 DeviceString. Intentional, not a bug.
            The question I think is given a DeviceRef, how do you get a lable, how to use GetLableForValue?
            tenholde
              Originally posted by alexbk66 View Post
              spud ?
              Where do I find GetStatusGraphic and GetStatusControl?
              tenholde
                In the general case label and status are different. Status text is formed from DeviceValue based upon the other device properties that have been set. Label is the text associated with a control. HS3 DeviceString is now HS4 EProperty.Status. The displayed text on a HS browser page is a function of DeviceValue+properties. DeviceString/Eproperty.Status are independent and take precedence in the rendering of text vs. DeviceValue+properties.
                  hs.GetStatusGraphicForValue(RefId, value);
                  hs.GetStatusControlForValue(RefId, value);
                    Am I missing something? This seems wierd.
                    AddStatusData =hs4.GetPropertyByRef(DevRef, EProperty.AdditionalStatusData) returns a List(of String)
                    While aStatusControl.GetLabelForValue(d, AddStatusData) requires String() for an argument? Makes me think I am doing something wrong?
                    tenholde
                      That's what I do:
Name:	Screenshot 2021-06-15 012422.jpg
                        public string GetLabelForValue(double value, string[] additionalData = null)
                          Thanks for your code. Essentially what I am doing. Just mystified why AdditionalData is List(of String) but the functions require it as String()
                          Thought I might be doing it the hard way.
                          tenholde
                            Often suffix is AdditionalData[0]
