how to auto refresh a page, and get a callback to postbackproc
    #16
    check upper/lower case, shouldn't be an issue but you never know, especially when you register your link and use of pluginId, your pathname which uses same pluginId, check they are consistently "Insteon" with capital I. Your registration should look something like
    RegisterFeaturePage("Insteon", "statuspage.html", "") and the statuspage.html must be in the \html\Insteon subdirectory
      #17
      i think i got it working (at least the POST part). thank you very much
      Mark
      HS3 Pro 4.2.17.0
        #18
        Glad to help. Not sure over time you want to have your page refreshing all the time, maybe that is not the intent but if you have questions, glad to share some sample code to refresh just div sections
          #19
          Ultimately, I do want to only refresh a couple of div sections...so I'm all ears.
          I need to be able to get the new div values from my plugin
          Mark
          HS3 Pro 4.2.17.0
            #20
            If there is a piece of info on the page that you want to update, put a <div></div> tag around it and make sure that <div> has an id that is unique, say <div id="veryuniqueInsteon">.
            So if you now postback every 2 seconds to your plugin, the plugin would verify if that info was changed and if so, the content of that div can be updated without updating the page.
            You make up your own syntax but upon receiving a response, what is crutial is the div id and the new content and then you update it something like the following
            $('#'+idivId).empty();
            $('#'+idivId).append(item.updateDivInfo);
              #21
              Hey Dirk,
              I got it working with the AjaxPost routine. it accepts a response type from postbackproc that will update divs for you without additional code; which is what i needed for now to get started.
              Return "[""statusmessage"",""" + gBkUpdate.StatusMessage + """,""primaryprogressmessage"",""" + gBkUpdate.PrimaryProgressMessage + """]"
              Mark
              HS3 Pro 4.2.17.0
                #22
                Hey Dirk,
                Awesome!
                  #23
                  Hey Dirk,
                  Can you lease provide more code example?
                    #24
                    BTW, in JS using Template Literals make string concatenation more readable
                    let a = 5; b = 10;
                    console.log('Sum of %d and %d is %d.', a, b, (a+b));
                    [EDIT]
                    In C#:
                    $"[\"{statusmessage}\",\"{gBkUpdate.StatusMessage}\",\"{primaryprogr essmessage}\",\"{gBkUpdate.PrimaryProgressMessage}\"]"
                      #25
                      ie
                      Originally posted by alexbk66 View Post
                      Can you please provide more code example?
                      Here are a few more return values that AjaxPost accepts and responses to:
                      refresh the current page; I use this after the user changes a filter select list
                      Result = "[""PAGE_refresh"",""true""]"
                      jump to a new page where NextPage is a variable containing the filename
                      Result = "[""PAGE_newpage"",""" + NextPage + """]"
                      Mark
                      HS3 Pro 4.2.17.0
                        #26
                        let a = 5; b = 10;
                        [EDIT]
                        In C#:
                        thanks for this; i'll give it a try
                        Mark
                        HS3 Pro 4.2.17.0
                          #27
                          You can insert variables directly into the string
                          let eggCount = 20;
                          console.log(`On easter we decorted ${eggCount}` easter eggs)
