inline select tag not rendered/stripped in hs4
    in hs3, I generate the following html via code
Name:	inline select html.png
    in hs4, the same code will not render the select/dropdown lists. i can see the code in the source
    i am retrieving the html code via a liquid tag (plugin_function) call from my html page
    i created a jui selectlistview, and i can pass that code via the same liquid tag, and it will render but the display isnt tight like the above
    what am i missing about using old html tags in hs4?
    Mark
    HS3 Pro 4.2.17.0
    Plugins: Insteon (mine) | Vista Alarm (mine) | Omnistat 3| Ultra1Wire3 | RFXCOM | NetCAM | HS MyQ | BLRadar | BLDenon | Jon00 Charting | Jon00 Links
    The HTML info is probably retrieved properly but the accompanying JavaScript code and CSS might be wrong.
      i finally found the culprit style (which is in the mdb.css) that causing the problem
      select {
      1. font-family: "Helvetica Neue", Helvetica, Arial, sans-serif;
      2. display: none !important;
      any suggestions on how to override this?
      Mark
      HS3 Pro 4.2.17.0
        for now i added the following to my html;
        <style>
        select {
        display: inline !important;
        </style>
        so now i get the expected results
        Mark
        HS3 Pro 4.2.17.0
          for the record, the SelectListView class generates a select element that is hidden by the above css
          Mark
          HS3 Pro 4.2.17.0
