how do i refresh a liquid tag without refreshing the page
    i have two liquid tags. I want the first to influence the second
    how can i do this without posting back to the plugin
    Mark
    HS3 Pro 4.2.17.0
    Plugins: Insteon (mine) | Vista Alarm (mine) | Omnistat 3| Ultra1Wire3 | RFXCOM | NetCAM | HS MyQ | BLRadar | BLDenon | Jon00 Charting | Jon00 Links
    But to refresh the liquid tags you do need to post back to get the new value?
      I was hoping to get the value from select 1 and submit that back to the liquid tag as an input
      Mark
      HS3 Pro 4.2.17.0
        Can you check the generated html to see what's in place for the liquid tag?
          could you post an example of what you are trying to do, not sure I follow. Liquid tags are server side converted into HTML, once that is done, not sure how you can do something with a post back or why you would even do so, because now your PI is "server side", you can generate any HTML you want in your response and update any div
            Maybe I'll ask different questions...
            I need to dynamically build a select element where the options change based on some other element on the html page
            (1) how do you decide if you do this with a liquid tag and doing a page refresh versus updating a div using ajax?
            (2) do you build select elements using the hs4 selectlistview class (there seems to be some bugs in this class) or just write standard html?
            Mark
            HS3 Pro 4.2.17.0
              I do everything in C# code. I have single template file and only replace the plugin name and page name.
              And plugin provides three functions: 'GetTitle', 'GetHTML' and 'GetJS' .
              And I do use hs4 selectlistview class
Name:	Screenshot 2021-11-08 235538.png
                Example:
Name:	Screenshot 2021-11-08 235312.png
                  Alex, thanks for posting; i think this will be helpful for others
                  have you found the selectlistview class doesn't generate the option keys correctly?
                  the below is hs4 generated code. I did not specify a zero for this option key. So when i post back, i need to regenerate the same option list just to get the correct option key based on the value (0).
                  <option value="0" selected="">Alert Alert  Module Alert: Alert  Module - Alert</option>
                  I think this is known issue; how do you work around this?
                  Mark
                  HS3 Pro 4.2.17.0
                    Yeah, selectlistview is a bit of a mess (like most of HST code)... It stores only the indexes, not keys.
                    So you need to keep the original SelectListView, then from the SelectListView returned from postback you get the selected index, then you get the original string from the original view:
Name:	Screenshot 2021-11-09 004230.png
Name:	Screenshot 2021-11-09 004325.png
                      And to keep the original SelectListView I have a map viewID => SelectListView
                      It also maps the view to the object and it's property - so when the postback is received - the map automatically updates the property value.
                      So the usage is pretty simple (but the internal code isn't) - i.e. when user selects the Language - the root.Language property is updated automatically:
                      pb.AddSelectListView("Language", root.Languages, root, nameof(root.Language));
Name:	Screenshot 2021-11-09 004629.png
                        You can do what Alex is doing, might be easiest but this would refresh the whole page, maybe not an issue. I do updates of div on client side using javascript code, maybe too complex, but I have a player/navigation function and reloading the page would be a no-no.
