preferred naming convention for plugin subfolders
    so my plugin ID is Insteon with a capital eye.
    do i use this name for my subfolder in the hs\html, html\images, and bin folders, or do i go all lower case?
    i know this doesn't matter on Windows but i had a lot of problems with linux in the past.
    With hs3 i found the homeseer subfolders (used mixed camel case) weren't consistent in the beginning and it cause me a lot of problems.
    even now when i debug in Chrome it separates Insteon from insteon in the page view navigator.
    Mark
    HS3 Pro 4.2.17.0
    Plugins: Insteon (mine) | Vista Alarm (mine) | Omnistat 3| Ultra1Wire3 | RFXCOM | NetCAM | HS MyQ | BLRadar | BLDenon | Jon00 Charting | Jon00 Links
    I use proper casing and never had any issues.
    Why even bother trying lowercase?
Name:	Screenshot 2021-11-23 105202.png
      do you support linux with your plugins?
      Mark
      HS3 Pro 4.2.17.0
        Yes
          To create the plugin specific path I have helper:
Name:	Screenshot 2021-11-23 135249.png
          And Plugin ID I extract from the Namespace:
Name:	Screenshot 2021-11-23 135433.png
            do you do this because the Updater using the install.txt doesn't build the folders correctly?
            Mark
            HS3 Pro 4.2.17.0
              I actually generate html files in source code.
              And most AKWeather icons download at runtime.
              And AKGoogleCast downloads translated mp3 files.
              And AKHeatmiserNeo generates temperature charts.
                And MakePluginPath returns the path to the folder for use in the plugin. CreateDirectory is "just-in-case".
