my plugin isn't being called when i click the HS Poll Devices icon on the hs devices page. all i get is this back.
anyone got UpdateStatusNow working
Mark
HS3 Pro 4.2.19.5
Platform: Windows Server 2022 Standard, i5-12600K/3.7GHz/10 core, 16GB RAM, 500GB SSDTags: None
when the user clicks the Poll Devices button, it should poll each device displayed for status, and then update the hs device page with statusMark
HS3 Pro 4.2.19.5
Originally posted by alexbk66 View Post
How does it poll the devices?
so for my insteon lighting plugin, i actually transmit a status request to the given device ref, get the response, and then update the hs device value
Mark
HS3 Pro 4.2.19.5
I'm not really up on this and haven't found the docs (if any) to explain the matter, but I think "polling" (or the ability thereof) is dependent on Z-Wave version. Since 3.0.2.0, I've lost the train of thought on which version does what.HomeSeer Version: HS4 Pro Edition 4.2.19.0 (Windows - Running as a Service)
Home Assistant 2024.3
Operating System: Microsoft Windows 11 Pro - Desktop
Z-Wave Devices via two Z-Net G3s
Zigbee Devices via RaspBee on RPi 3b+
WiFi Devices via Internal Router.
Enabled Plug-Ins
AK GoogleCalendar 4.0.4.16,AK HomeAssistant 4.0.1.23,AK SmartDevice 4.0.5.1,AK Weather 4.0.5.181,AmbientWeather 3.0.1.9,Big6 3.44.0.0,BLBackup 2.0.64.0,BLGData 3.0.55.0,BLLock 3.0.39.0,BLUPS 2.0.26.0,Device History 4.5.1.1,EasyTrigger 3.0.0.76,Harmony Hub 4.0.14.0,HSBuddy 4.51.303.0,JowiHue 4.1.4.0,LG ThinQ 4.0.26.0,ONVIF Events 1.0.0.5,SDJ-Health 3.1.1.9,TPLinkSmartHome4 2022.12.30.0,UltraCID3 3.0.6681.34300,Z-Wave 4.1.3.0
It is pretty simple, just do this in HSPI.vb:
Code:Overrides Function UpdateStatusNow(devOrFeatRef As Integer) As EPollResponse ' Do whatever you need to do to poll devOrFeatRef Return EPollResponse.Ok End Function
stefxx
I'm getting the above error in 4.2.6.0. I'm not messing with HS4 betas right now.
I need to provide a polling capability; physical lights and hs are never 100% in sync.Mark
HS3 Pro 4.2.19.5
Not sure what "messing with HS4 betas" has to do with it. But if you are getting the same error in 4.2.6.0 also then I guess the bug was introduced earlier already.
I know that it worked before - when I implemented this weeks ago, just after they released this function. I think that was in version 4.2.5.0.
I suggest you create a bug report.stefxx
turns out this is a bug. if the plugin ID is different from the Name property, it doesn't work. Rich is putting in a fix.
i guess they were keying off the Name property instead of the ID.
Mark
HS3 Pro 4.2.19.5
- Likes 1
