Setting suffix for value range in code
    Can somebody please explain how to properly add suffix to the display value (i.e. %) if the range has control (slider) and different icons (Status/Graphics) for sub-ranges?
    I managed to make it work, but still confused and really it doesn't make much sense to me.
    Where do I set the suffix? For the control (slider) or the Status/Graphics?
    For the control (slider) I just set: Suffix = "%"
    For Status/Graphics sub-ranges I set AdditionalData, it works, but in the device range configuration the Suffix is $%0$
    statusGraphic.TargetRange.Suffix = HsFeature.GetAdditionalDataToken(0);
    statusGraphic.HasAdditionalData = true;
    AdditionalStatusData = new List<string>() { "%" };
    As I said - it works, but I don't understand. What's the meaning of HasAdditionalData, especially for the control?
    For the control (slider) For Status/Graphics sub-ranges
    Click image for larger version  Name:	2022-03-02 (3).png Views:	0 Size:	11.6 KB ID:	1529924 Click image for larger version  Name:	2022-03-02 (4).png Views:	0 Size:	10.5 KB ID:	1529925
    Click image for larger version  Name:	2022-03-02 (2).png Views:	0 Size:	72.8 KB ID:	1529923
    AdditionalData is designed to be used as replacement tokens, so you should use it only if your suffix can change at runtime, for example a temperature device which could be either " °C" or " °F"
    HS.UpdatePropertyByRef(dvRef, EProperty.AdditionalStatusData, new List<string>() { thermostat.Settings.UseCelsius ? " °C" : " °F" });
    if your suffix is always "%", then do not use any AdditionalData and set the range suffix to "%" in your StatusControl and StatusGraphic
      What's the meaning of AdditionalData for the Controls anyway? Doesn't it only apply to Status?
        No it can apply to controls too. Imagine instead of a slider you use a dropdown list for a control that set a temperature, you may want your values in that dropdown list to appear as either " °C" or " °F"
