Acceptable plugin startup time and returning an appropriate OnStatusCheck message
    on a clean startup, my plugin may take up to 5-10 seconds if all goes well.
    hs4 doesn't seem to like that and sometimes posts an error message on the plugin tile on the plugins/manage page (instead of calling OnStatusCheck and getting my status)
    i tried starting on my own thread but that seemed to cause problems registering feature pages. maybe i should try this again
    what are you guys doing to make the OnStatusCheck return message useful?
    Mark
    HS3 Pro 4.2.17.0
    Plugins: Insteon (mine) | Vista Alarm (mine) | Omnistat 3| Ultra1Wire3 | RFXCOM | NetCAM | HS MyQ | BLRadar | BLDenon | Jon00 Charting | Jon00 Links
    First thing I do, is start a very short timer and do just the basic house keeping items that take no time, then immediately return to HS4. When the timer expires, I do all the heavy lifting such as discovering players (up to 30 seconds), create all the devices, check for inconsistencies etc. If anything goes wrong during that extended intialization period, I change the status and provide a warning or error.
      I register all pages (RegisterDeviceIncPage and RegisterFeaturePage), check for valid DotNet/Mono version, and if that is OK I start a new thread. Finally I set the status to PluginStatus.Ok.
      That is all my Initialize sub contains. Usually returns within a few milliseconds. If anything goes horribly wrong later I set the status to something like PluginStatus.Fatal.
      stefxx
        +1 For initialising plugin in a thread. I'm using Task.Factory.StartNew
