Any way to tell if a trigger is a condition?
    I've got a trigger with a few sub-triggers which can all be conditions, but I'd like to show a different string for the sub-trigger names depending on whether the trigger is presently a condition, since the triggers fire when state changes but conditions check present state. I've looked at all the properties and methods available in AbstractTriggerType but I haven't found any way to check whether the currently configured trigger is a condition or not. Is this possible?
    there is a property that indicates if the trigger can also be used as condition
    Public Overrides ReadOnly Property CanBeCondition As Boolean
    Get
    Return False
    End Get
    End Property
    Mark
    HS3 Pro 4.2.17.0
    Plugins: Insteon (mine) | Vista Alarm (mine) | Omnistat 3| Ultra1Wire3 | RFXCOM | NetCAM | HS MyQ | BLRadar | BLDenon | Jon00 Charting | Jon00 Links
      Right, I've got the trigger working properly as a condition, I just want to see at UI-render-time whether the current trigger instance is a condition, so I can change the sub-trigger names.
        https://github.com/HomeSeer/Plugin-SDK/issues/277
        https://github.com/HomeSeer/Plugin-SDK/issues/237
