Moving child to different root
    Anybody have working code example for moving child to different root?
    It should be simple as dev.SetParent(int newRoot) - but it's not...
    spud​​​​​​​ ?
    dont you have to break the relationship between the root and the child as well. i recall each is related to the other
    Mark
    HS3 Pro 4.2.19.5
      I don't have a working code example, but did you try using AbstractHsDevice.AssociatedDevices or EProperty.AssociatedDevices
      Using this property you should:
      • remove the child ref from the old root
      • add the child ref to the new root
      • change the root ref on the child
        Yeah, that's what I've done, a bit messy
        public virtual void SetParent(DeviceBase par)
           // Current root
           CheckIfRoot();
           if (rootRef == par.RefId)
              return;
           LogWarn($"Changing root device from {rootRef} to {par.RefId}");
           if (!par.isRoot)
              LogWarn($"New Parent is not root device");
              return;
           // HS AssociatedDevices
           this.Disassociate();
           // Add new parent to this association
           this.AddAssocDevice(par.RefId);
           // Add this child to new parent association
           par.AddAssocDevice(this.RefId);
           // DeviceBase parent/child
           this.Location = par.Location;
           this.Location2 = par.Location2;
           root?.RemoveChild(this);
           par.AddChild(this);
           // Finally set root
           this.root = par;
        public List<DeviceBase> AssociatedDevices
           get
              List<DeviceBase> ad = new List<DeviceBase>();
              HashSet<int> refs = AssociatedDeviceRefs;
              foreach (int iref in refs)
                 DeviceBase dev = controller.GetDevice(iref, create: true);
                 ad.Add(dev);
              return ad;
        /// <summary>
        /// Remove AssociatedDevices and this device from other AssociatedDevices
        /// </summary>
        public void Disassociate()
           HashSet<int> assoc = AssociatedDeviceRefs;
           foreach (int dRef in assoc)
              // Remove parent association
              RemoveAssocDevice(dRef);
              // Remove this child from parent association
              controller.GetDevice(dRef)?.RemoveAssocDevice(this.RefId);
        /// <summary>
        /// RemoveAssocDevice
        /// </summary>
        /// <param name="dRef"></param>
        public void RemoveAssocDevice(int dRef)
           if (assoc.Contains(dRef))
              Log($"RemoveAssocDevice {dRef}");
              assoc.Remove(dRef);
           AssociatedDeviceRefs = assoc;
        /// <summary>
        /// AddAssocDevice
        /// </summary>
        public void AddAssocDevice(int dRef)
           Log($"AddAssocDevice {dRef}");
           assoc.Add(dRef);
