Checking if device address exists?
    What's the best way to check if device address exists?
    hs.GetDeviceByAddress should return an object if the address exists. otherwise you get nothing
    Mark
    HS3 Pro 4.2.17.0
    Plugins: Insteon (mine) | Vista Alarm (mine) | Omnistat 3| Ultra1Wire3 | RFXCOM | NetCAM | HS MyQ | BLRadar | BLDenon | Jon00 Charting | Jon00 Links
      This I know, but (1) it's not very efficient and (2) messy since you need to know if it's a "device" or "feature".
Name:	Screenshot 2022-07-27 003006.png
        what's the alternative? you to enumerate through all the devices and/or features until you find a hit
        Mark
        HS3 Pro 4.2.17.0
          I think that also generates a log event from HS that something is iterating through all the devices.
          67 Z-Wave Nodes, 111 Events, 422 Devices
          Z-Wave, UPB, WiFi
          Plugins: EasyTrigger, weatherXML, OMNI, Z-Wave, Tuya, Device History
            What about hs.DoesRefExist?
            stefxx
              It's "ref", not address
                DeviceExistsAddress or DeviceExistsAddressFull
                Scripts =
                Various
                  That's what I'm after, but where? IHsController doesn't have it.
                    Correct, my bad.
                    stefxx
                      I found it here but not sure about in the sdk.
                      Scripts =
                      Various
                        That would be under the HS3 HomeSeerAPI.IHSApplication
                        Jon
                          yeah, found in HomeSeerAPI.IHSApplication - will give it a try
                            Yep, it works, thank you enigmatheatre jon00
                              A question related to this... Is there a script or easy method to generate a simple list of devices and their refs and address? Something that I can use to sort or search on? I don't see in the HS4 UI such a simple data grid view with selectable headers for sorting.
