Checking if device address exists?
    #16
    Originally posted by davidcald View Post
    A question related to this... Is there a script or easy method to generate a simple list of devices and their refs and address? Something that I can use to sort or search on? I don't see in the HS4 UI such a simple data grid view with selectable headers for sorting.
    How about this? https://forums.homeseer.com/forum/3r...for-homeseer-4
    Jon
      #17
      Originally posted by jon00 View Post
      Hey Jon-
      YES I have your utility installed! It's one of my many issues that with HS there's so many plugins and scripts and addons that I lose track of things I've installed for good reason and forget the reason. Anyway, I just ran the utility (v1.0.5) and get this error:
      Error in Main Block 1: System.IndexOutOfRangeException: Index was outside the bounds of the array. at System.Array.InternalGetReference(Void* elemRef, Int32 rank, Int32* pIndices) at System.Array.GetValue(Int32 index) at Microsoft.VisualBasic.CompilerServices.Symbols.Container.Get ArrayValue(Object[] Indices) at Microsoft.VisualBasic.CompilerServices.NewLateBinding.Intern alLateIndexGet(Object Instance, Object[] Arguments, String[] ArgumentNames, Boolean ReportErrors, ResolutionFailure& Failure, Boolean[] CopyBack) at Microsoft.VisualBasic.CompilerServices.NewLateBinding.Object LateInvokeDefault(Object Instance, Object[] Arguments, String[] ArgumentNames, Boolean ReportErrors, Boolean[] CopyBack) at Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateIn dexGet(Object Instance, Object[] Arguments, String[] ArgumentNames) at scriptcode13.VBWrapper.Main(Object MyData)
        #18
        Odd...If you updated, did you replace the Jon00DeviceViewer.aspx file?
        Jon
          #19
          Looks like that was it all good now thanks!
