SelectListView with GridView not working properly in ActionPage
    I am creating an ActionType from plugin. In my ActionType.OnNewAction I have initialized the page as follows,
    gridRow.AddItem(...select list view 1)
    gridView.AddRow(gridRow)
    pageFactory.WithView(gridView)
    ConfigPage = pageFactory.Page
    In ActionType.OnConfigItemUpdate when the select list view 1 changes, I have added two new select list views and return true as follows,
    // Again creating an already existing select list view
    // Adding new select list views
    gridRow.AddItem(...select list view 2)
    gridRow.AddItem(...select list view 3)
    return true
    In ActionType.OnConfigItemUpdate when the select list view 2 or select list view 3 changes, I have just returned true.
    This is where I am facing the issue. The data of select list view 2 and 3 is saved and we can check that using <select list view 2>.Selection. But the select list view in UI does not reflect this. It shows "Select a value".
    What can be the reason for this?
    You'll need to post this question on the Github : Issues ยท HomeSeer/Plugin-SDK (github.com)
    67 Z-Wave Nodes, 111 Events, 422 Devices
    Z-Wave, UPB, WiFi
    Plugins: EasyTrigger, weatherXML, OMNI, Z-Wave, Tuya, Device History
      Create issue https://github.com/HomeSeer/Plugin-SDK/issues/314
