Error >>>>
Starting up..
10/28/2022 4:25:12 PM HomeSeer~!~Error~!~Exception starting database services, Could not load type 'HomeSeer.PluginSdk.Systems.EConfigChangeTarget' from assembly 'PluginSdk, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null'.Startup Complete, 1 errors detected, check the log for more information.
Logs >>>>
10/28/2022 4:25:11 PM HomeSeer~!~Database~!~Opening (Mode=Read Only) up HomeSeer LOG database C:\Program Files (x86)\HomeSeer HS4\Logs\HomeSeerLog.hsd
10/28/2022 4:25:12 PM HomeSeer~!~Startup~!~Loading Settings
10/28/2022 4:25:12 PM HomeSeer~!~Startup~!~Settings Loaded.
10/28/2022 4:25:12 PM HomeSeer~!~startup~!~
10/28/2022 4:25:12 PM HomeSeer~!~startup~!~*************************************** *****************************************
10/28/2022 4:25:12 PM HomeSeer~!~startup~!~ HomeSeerVersion 4.2.16.0 Edition: HS4 Standard StartingNow
10/28/2022 4:25:12 PM HomeSeer~!~Startup~!~Creating Class Objects...
10/28/2022 4:25:12 PM HomeSeer~!~Startup~!~COM port classes started.
10/28/2022 4:25:12 PM HomeSeer~!~Startup~!~Application interface class started.
10/28/2022 4:25:12 PM HomeSeer~!~Startup~!~Web server class started.
10/28/2022 4:25:12 PM HomeSeer~!~Startup~!~E-Mail SEND class started.
10/28/2022 4:25:12 PM HomeSeer~!~Startup~!~E-Mail RECEIVE class started.
10/28/2022 4:25:12 PM HomeSeer~!~Startup~!~Plug-In Interface class started.
10/28/2022 4:25:12 PM HomeSeer~!~Startup~!~Local voice recognition class started.
10/28/2022 4:25:12 PM HomeSeer~!~Startup~!~Loading configuration file ...
10/28/2022 4:25:12 PM HomeSeer~!~Info~!~Loaded 115 Devices.
10/28/2022 4:25:12 PM HomeSeer~!~Startup~!~HomeSeer version is: 4.2.16.0
10/28/2022 4:25:12 PM HomeSeer~!~Startup~!~Creating Speaker Client Interface Object...
10/28/2022 4:25:12 PM HomeSeer~!~Startup~!~This version of HomeSeer is registered as a HS4STANDARD version.
Starting up..
Logs >>>>
