Cannot update the plugin name of already installed plugin
    I have an existing plugin created by me installed in my HS4. Now I updated the PluginName property of AbstractPlugin as I want to change the display name of my plugin. After I install the latest version of my plugin, the plugin's display name is not updated. Also, its status is not Ok. It shows the status Loaded Remotely.
    Should I create an issue for this on GitHub or is it a known issue?
    Search the GitHub https://github.com/HomeSeer/Plugin-SDK/issues but I don't think it's a known issue. Then yes, create.
    [EDIT]
    There's an issue (closed) with similar problem https://github.com/HomeSeer/Plugin-SDK/issues/77
    It mentions "The .json file deposited by the Updater into the HS4 folder contains the product name".
    Check your HSPI_xxxx.exe.json for "plugin_name" and "PackageName"
    Looks like a bug still...
      Created issue #347
