Let's say I want to write an HS4 plugin, using the new bootstrap UI. This new plugin would then only run on HS4.
If I want an HS3 version of the plugin, I have to write an HS3 plugin, then be stuck with the old JQuery interface in HS4?
Now I have an HS3 plugin and an HS4 plugin to maintain?
What's my incentive to write a new plugin for HS4 if it wont run on HS3?
I'm trying to figure out the best direction for developing a *new* plugin, not migrating an existing one from HS3. What would you do?
