The subforum is a step in the right direction, but I think after a while it will become unmanageable for Developers and HST. Has any consideration been given to using a proper bug/issue tracker? I think someomone mentioned you have code up on GitHub, why not use their issue tracker?
If you use AzureDevOps, Jira, et al, they each should allow you to grant limited access to create bugs and track them.
