HS3 PIs that create devices that use dvMISC.CONTROL_POPUP are not controllable in HS4
    I set this value when I create my master device in an HS3 based PI:
    dv.MISC_Set(hs, Enums.dvMISC.CONTROL_POPUP)
    which results in:
    Click image for larger version  Name:	HSControl.png Views:	0 Size:	132.2 KB ID:	1326597
    doesn't seem to show up when the PI runs in HS4. Perhaps the "Control" button that shows up for each device is suppossed to take care of that?
    Click image for larger version  Name:	HSControl1.png Views:	0 Size:	379.6 KB ID:	1326598
    bump rjh
    This is a HS3 PI under HS4 issue and prevents me from testing a bunch of features.
    I also just noticed that the "Player" devices have a same but different problem.
    See attached the HS3 and HS4 screenshot.
    As you can see, in the HS4 view, all the status info is missing and all the control buttons.
    Thanks for looking into this.
    Dirk
      Status should display in the next update. The popup control has not been coded yet. I bet you are the only one using that! But I plan on using that for the media controls.
