I was wondering if there is a list of hs plug-in calls, for use in our plugins? Would be nice if the calls were documented with namespace and sintax, ie. hs.WriteLog, etc..
Is there a list of hs plug-in API calls?
-Larry
A member of "The HA Pioneer Group", MyWebSite
Plugins:
VWS, AB8SS, lrpSpeak, Calendar, Arduino, Harmony, BlueIris, Sprinklers, ZipBackup...
Hardware:
Intel NUC8i7BEH1 running Windows 10 Pro headless, HS3 Pro, Plex running on Synology dual High Availability DS-1815+ NAS (24Tb each), Synology Surveillance Station running on DS-416 Slim (8Tb), Samsung SmartThings, Google Home, Alexa, Hubitat Elevation, ZNET, Ubiquiti UniFi Network, Davis Vantage Pro II Weather Station. Whole house speaker system using a couple of AB8SS switches. Vantage Pro II Weather Station, Rain8Net Sprinklers, Hubitat Elevation, Google Home, Alexa, DSC Security System, Ubiquiti UniFi Network.Tags: None
Originally posted by lpitman View PostI was wondering if there is a list of hs plug-in calls, for use in our plugins? Would be nice if the calls were documented with namespace and sintax, ie. hs.WriteLog, etc..
Are you referring to the plugin SDK docs located here: https://docs.homeseer.com/display/HSPI
I am trying to determine for example: hs.WriteLog call. What is the equivalent call in the new API?-Larry
Plugins:
Hardware:
But only inside the hspi class, not outside. I am having the same issue. It feels like you have to do all inside the hspi, which would create a very large hspi vlass.
how does one call hs.writelog from another part of the plugin? Would have expected something in PluginSDK.logging? But that is only holding a single value?-- Wim
Originally posted by lpitman View PostI am trying to determine for example: hs.WriteLog call. What is the equivalent call in the new API?
Greig.
Sent from my SM-G973F using Tapatalk
Scripts = Various
In HS3 we had :
Code:IHSApplication.WriteLog(string mtype, string message)
Code:IHsController.WriteLog(ELogType logType, string message, string pluginName, string color = "")
- Likes 1
Thanks for your reply. I am self-taught and am not quite getting passing the HomeSeerSystem object to any other class to work can you give me an example of this?
Greig.
Sent from my SM-G973F using TapatalkZwave = Z-Stick, 3xHSM100� 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
Scripts = Various
Greig.
You can pass it as a parameter of the constructor of all your other classes: MyClass a = new MyClass(HomeSeerSystem), or you could define a singleton design pattern to be able to access it from anywhere, or any other method you used in HS3.
Thanks for the responses, This isn't that intuitive for a lot of us self taught programmers. More examples would certainly help. I think probably since this is alpha, the sample program source was very sparse, compared to maybe later when beta is available.-Larry
Plugins:
Hardware:
How did you do it in HS3?
So My plugin would spin up controllers/services and pass in the hspi class to reference for calling back to HS. Allowed me to have a nice separation of business logic and HSPI logic.
Greig.
-Larry
Plugins:
Hardware:
I give up, none of the suggestions above work for me. We need a complete example of a plugin, that includes creating devices, writing to log, and interfacing HS calls into our modules, class files!!!
I can get the sample plugin to run without problems but whenever I try and add any calls to HS the plugin crashes. In HS3 I had a public member that I would callCode:Public hs As HomeSeerAPI.IHSApplication
Code:Public HS4 As HomeSeer.PluginSdk.IHsController
Code:HS4.WriteLog(Logging.ELogType.Info, "Test Message", "Test Name")
I am probably doing something dumb but I just can't work it out.
Greig.Zwave = Z-Stick, 3xHSM100� 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
Scripts = Various
Here is an example that I could understand...
Code:Public Class ClsComm ' Serial port specific constants and globals Public Shared RS232Port As New System.IO.Ports.SerialPort #Region " My CommPort Functions " '**************************************************************************** ' CloseComPort is used to close the communications port. Friend Shared Sub CloseComPort() ClsHelper.OutputHSLog("Entering CloseComPort()....", DEBUG_LOGGING, "Debug", COLOR_ORANGE) With RS232Port Try If .IsOpen = True Then .Close() ClsHelper.OutputHSLog(gComPort & " Closed.", NORMAL_LOGGING, "Info", COLOR_BLACK) End If Catch ex As Exception ClsHelper.OutputHSLog("Exception error in CloseComPort(): " & ex.Message, MANDATORY_LOGGING, "Error", COLOR_RED) ' Handle exception error End Try End With End Sub
-Larry
Plugins:
Hardware:
