If I change the device view to list view the log is flooded with errors:
Then if I return to tile view, another error is thrown in the log (only once)
After that the CPU rises to 100% (shared browser and HS4) for some time. It will go back after a while to normal.
Wim
Edit: this is with v4.0.0.18
18-9-2019 11:43:15 Error In SettingManager getVar setting var false: var not found 18-9-2019 11:43:15 Error In SettingManager getVar setting var false: var not found 18-9-2019 11:43:15 Error In SettingManager getVar setting var false: var not found 18-9-2019 11:43:15 Error In SettingManager getVar setting var false: var not found 18-9-2019 11:43:15 Error In SettingManager getVar setting var false: var not found 18-9-2019 11:43:15 Error In SettingManager getVar setting var false: var not found 18-9-2019 11:43:15 Error In SettingManager getVar setting var false: var not found 18-9-2019 11:43:15 Error In SettingManager getVar setting var false: var not found 18-9-2019 11:43:15 Error In SettingManager getVar setting var false: var not found <SNIP>
18-9-2019 11:43:31 Error In SettingManager setVar setting var gDeviceViewList: De objectverwijzing is niet op een exemplaar van een object ingesteld.
Wim
