mcsXap evaluation
No issues. Only update that will be required is in the updater package. mcsXap was using the System.Data.SQLite.dll used by HS and now needs it to be \bin\mcsXap.
mcsSprinklers evaluation.
When viewing mcsSprinklers page from browser get "Error finding plugin in GenPage: Unable to cast object of type 'Scheduler.PluginHolder' to type 'HomeSeerAPI.IAllRemoteAPI'." Since all mcsSprinklers UI goes through GenPage no further evaluation is possible to do a setup for evaluation. There were no startup errors in the HS log.
Suggest GenPage be added to HS4. This is significant for continued use of mcsSprinklers as it shares a common code base with standalone mcsSprinklers.
mcsMQTT evaluation.
Initial evaluation showed no problem navigating the mcsMQTT pages.
I was able to create a HS4 device from it and used /DeviceUtility to view and control with results as expected.
For Event triggers and actions I have generally good result expect for the MQTT Broker Connection trigger that has pulldown selector and two buttons. The control boxes for these two do not appear. (HS4.png) The static text does appear. The generating code segment is below:
HS4 - error
HS3 - normal
mcsMQTT evaluation.
HS4 - error
HS3 - normal
Dim stb As New StringBuilder Dim UID As String UID = TrigInfo.UID.ToString If gMQTTBroker.Length > 1 Then stb.Append(NBSP) stb.Append("of Broker at ") Dim dl As New clsJQuery.jqDropList("MqttBroker_" & UID & sUnique, Pagename, True) For i As Integer = 0 To gMQTTBroker.Length - 1 Dim sKey As String = gMQTTBroker(i) If Trig3.Broker = i Then dl.AddItem(sKey, sKey, True) Else dl.AddItem(sKey, sKey, False) End If Next dl.toolTip = "Select Broker for connection event trigger" stb.Append(dl.Build()) stb.Append(NBSP) End If Dim rb As New clsJQuery.jqRadioButton("MqttConnect_" & UID & sUnique, Pagename, True) Dim sProperty As String If Trig3.Connected Then sProperty = ONE Else sProperty = ZERO End If rb.values.Add("Disconnects from Broker", ZERO) rb.values.Add("Connects to Broker", ONE) If sProperty = ZERO Then rb.checked = ZERO Else rb.checked = ONE End If stb.Append(rb.Build()) Dim s As String = stb.ToString stb = Nothing Return s
