Originally posted by rjh
View Post
Is there a visual tool to build the HTML pages with liquid tags and bootstrap code?
I bit the bullet and bought PineGrow. Like Rich said, it's great for laying out pages, but once the tags are added, it looks bad.
Anyone else using PineGrow for their HS4 plugins?HS4Pro on a Raspberry Pi4
HSTouch Clients: 1 Android
Originally posted by rmasonjr View PostI bit the bullet and bought PineGrow. Like Rich said, it's great for laying out pages, but once the tags are added, it looks bad.
So in summary, it sits somewhere on my dev computer and I opened it about 5 times and was done after 10 min. If someone had better experience and/or have advice how to best use, I'd be all ears.
dcorsus when you open PineGrow, dont open just a file, open the entire html folder in HS and it will automatically load all the bootstrap files for WYSIWYG. You can then hit Ctrl-E to edit and make changes and see the changes realtime.
Since adding the tags borks the page, I have removed all the tags until I get the layout exactly like I want. I just use placeholders and go back and replace them with the tags using UltraEdit.
Originally posted by dcorsus View PostThanks for the pointer, need to give that a try. My html files are not with all the HS html files, does that mean for testing/dev I should move my html files to the \html folder?HS4Pro on a Raspberry Pi4
