Where and how do we set AccessLevel() ?
ie. Free or Key Required
If this is your first visit, be sure to check out the FAQ. You must register before you can post.
IMPORTANT: Your first post will be checked for appropriate content. This may take a bit of time.
Public Overrides ReadOnly Property AccessLevel As Integer Implements HomeSeer.PluginSdk.IPlugin.AccessLevel Get ' return the access level for this plugin ' 1=everyone can access, no protection ' 2=level 2 plugin. Level 2 license required to run this plugin Return 1 End Get End Property
