According to page_common.js, divtoupdate isn't implemented:
HomeSeer owes us a more useful API and documentation!!! We shouldn't have to re-invent the wheel for every possible senario and re-code javascripts and postbacks as referenced above. This is a serious set back for me and I may never upgrade my plugins anytime soon as I can not justify the effort required for such a small sales price that is shared with HS.
The issue I had was that jQuery. styles don't work well with the HS4 styles. Choice then becomes to have HTML-focused pages or have the plugin build the page as was done with HS3. I wanted to keep my page construction logic in the plugin as it is very complex to provide a dynamic user experience. This means I needed to make the controls I use comply with the HS4 bootstrap/jui css. I'm certain I will tweak these as I learn more about using css and in particular what is available in the HS4 css files.
I provided the write up to help others that may be trying to go down the same overall path that I took. There are various things I covered and tried to provide the rationale. It is not intended to be a final solution for everybody, but just a sample that has a little more documentation in areas than is not found in the HS samples.
