Retrieving Settings from INI file
    Is there away to retrieve my settings when the plugin loads without creating Protected Overloads Sub LoadSettingsFromIni() ? The settings page reads in the values fine, but how do I access them in my plugin?
    -Larry
    A member of "The HA Pioneer Group", MyWebSite
    Plugins:
    VWS, AB8SS, lrpSpeak, Calendar, Arduino, Harmony, BlueIris, Sprinklers, ZipBackup...
    Hardware:
    Intel NUC8i7BEH1 running Windows 10 Pro headless, HS3 Pro, Plex running on Synology dual High Availability DS-1815+ NAS (24Tb each), Synology Surveillance Station running on DS-416 Slim (8Tb), Samsung SmartThings, Google Home, Alexa, Hubitat Elevation, ZNET, Ubiquiti UniFi Network, Davis Vantage Pro II Weather Station. Whole house speaker system using a couple of AB8SS switches. Vantage Pro II Weather Station, Rain8Net Sprinklers, Hubitat Elevation, Google Home, Alexa, DSC Security System, Ubiquiti UniFi Network.
    +1 following...
    72 Z-Wave Nodes, 111 Events, 422 Devices
    Z-Wave, UPB, WiFi
    Plugins: EasyTrigger, weatherXML, OMNI, Z-Wave, Tuya, Device History
      Use HomeseerSystem.GetIniSetting
      The section is “Settings” but you can see that if you open the ini file
        duh, I should have figured that one out...I guess I'm a little frazzled trying to get this plugin done.
        -Larry
        Plugins:
        Hardware:
          do you guys trusts the hs3/4 built-in ini routines? i gave up on them in HS3, and implemented a third party ini class. My HS3 ini file kept getting truncated/corrupted when hs3 crashed or was shutdown in correctly
          Mark
          HS3 Pro 3.0.0.534
            I've never had an issue with the built-in routines. I am writing a new plugin that will 'cache' the INI settings instead of reading them for every device event. I've even thought about a built-in timer to get any new settings every 'x' minutes or so.
            Z-Wave, UPB, WiFi
              Never had any issue with it but I don't use it as a streaming database, just for settings and they are easily a few hundred entries.
                I used my own and not HS3's
                -Larry
                Plugins:
                Hardware:
                  1.) GetIniSetting works great to retrieve settings for my subs/functions.
                  2.) But the settings page doesn't read anything in except toggles, and seems to ignore my text input.
                  3.) The settings page does save any changes I make to the correct pluginname.ini file, but on startup it only reads the toggles???
                  So I still am forced to use my routine to retrieve the data reliably.
                  -Larry
                  Plugins:
                  Hardware:
                    I store booleans, text and integers as part of the settings page. They do require use of different kind of:
                    withToggle
                    withInput
                    withDropDownSelect
                    Seems to work for me but text is simple not chapters long with potential conflict in characters like "=" or crlf
                      That's how I do it for PED, but you can also apply it to ini settings
                      public bool use_status_device
                          get
                              if(_use_status_device == null)
                                  _use_status_device = GetPED<bool>(Utils.FuncName());
                              return (bool)_use_status_device;
                          set
                              _use_status_device = value;
                              SavePED(Utils.FuncName(), _use_status_device);
                      bool? _use_status_device;
                        withToggle
                        withInput
                        withDropDownSelect
                        Thats the same as I'm using?
                        'Add a TEXT INPUTVIEW to the page
                        settingsPage.WithInput(Constants.Settings.FourthAnnounceId, Constants.Settings.FourthAnnounceName, HomeSeer.Jui.Types.EInputType.Text)
                        settingsPage.WithInput(Constants.Settings.FromEmailId, Constants.Settings.FromEmailName, HomeSeer.Jui.Types.EInputType.Email)
                        settingsPage.WithInput(Constants.Settings.EmailServerId, Constants.Settings.EmailServerName, HomeSeer.Jui.Types.EInputType.Text)
                        settingsPage.WithInput(Constants.Settings.EmailPasswordId, Constants.Settings.EmailPasswordName, HomeSeer.Jui.Types.EInputType.Password)
                        'Add the page to the list of plugin settings pages
                        Settings.Add(settingsPage.Page)
                        -Larry
                        Plugins:
                        Hardware:
                          Check the parameters. Parameter 3 is a value and 4 is some type. I don't see you setting the value and in my code I don't set the type which is optional
                          HTML Code:
                                      settingsPage1.WithDropDownSelectList(Constants.Settings.Sp1DebugLevelOptionsId, Constants.Settings.Sp1DebugLevelOptionsName, Constants.Settings.Sp1DebugLevelOptions, DebugLevel.dlErrorsOnly)
                                      settingsPage1.WithDropDownSelectList(Constants.Settings.Sp1UPNPDebugLevelOptionsId, Constants.Settings.Sp1UPNPDebugLevelOptionsName, Constants.Settings.Sp1UPNPDebugLevelOptions, DebugLevel.dlErrorsOnly)
                                      settingsPage1.WithToggle(Constants.Settings.Sp1DebugToggleLogtoDiskToggleId, Constants.Settings.Sp1LogtoDiskToggleName)
                                      'Add the Music DB Setting Label to the page
                                      settingsPage1.WithLabel(Constants.Settings.Sp1MusicDBLabelId, Nothing, Constants.Settings.Sp1MusicDBLabelValue)
                                      settingsPage1.WithToggle(Constants.Settings.Sp1AutoUpdateFlagId, Constants.Settings.Sp1AutoUpdateFlagName, True)
                                      settingsPage1.WithToggle(Constants.Settings.Sp1ImmediateUpdateFlagId, Constants.Settings.Sp1ImmediateUpdateFlagName, False)
                                      settingsPage1.WithToggle(Constants.Settings.Sp1LearnRadioStationsFlagId, Constants.Settings.Sp1LearnRadioStationsFlagName, True)
                                      settingsPage1.WithInput(Constants.Settings.Sp1AutoUpdateTimeId, Constants.Settings.Sp1AutoUpdateTimeInputBoxName, "02:10")
                            Settings Page does save settings in INI file, but does not load them on startup. I have to toggle off then toggle on things like Debug Checkbox and other configuration items.
                            -Larry
                            Plugins:
                            Hardware:
                              During initialization I load my settings into local variables
                                      public void Load()
                                          Location = _hs.GetINISetting("Settings", "Location", "Hubitat", Utils.IniFile);//I Like it When I can Set a Default location myself
                                          Location2 = _hs.GetINISetting("Settings", "Location2", "Hubitat", Utils.IniFile);
                                          DebugLog = bool.Parse(_hs.GetINISetting("Settings", "DebugLog", "false", Utils.IniFile));
                                          MakerURI = _hs.GetINISetting("Settings", "MakerURI", "", Utils.IniFile);
                              I then use them to initialize my settings page and also in response to the setting page save
                                      private void InitializeSettingsPages()
                                          //Start a PageFactory to construct the Page
                                          var settingsPage1 = PageFactory.CreateSettingsPage("idConfig", "Config");
                                          //Add a LabelView to the page
                                          settingsPage1.WithLabel("idlblMakerAPIURL", null, "Hubitat Maker API URL:"); //"Config");
                                          //Add a text InputView for the Maker API text
                                          settingsPage1.WithInput("idtxtMakerAPIURL", "MakerAPI URL", _settings.MakerURI, HomeSeer.Jui.Types.EInputType.Text);
                                          settingsPage1.WithInput("idtxtLocation", "Floor (Location2)", _settings.Location2, HomeSeer.Jui.Types.EInputType.Text);
                                          settingsPage1.WithInput("idtxtLocation2", "Room (Location)", _settings.Location, HomeSeer.Jui.Types.EInputType.Text);
                                          //Add a checkbox to the page for Debug
                                          settingsPage1.WithCheckBox("idchkDebug", "Debug", _settings.DebugLog);
                                          //Add the first page to the list of plugin settings pages HomeSeer.Jui.Views.SettingsCollection.
                                          Settings.Add(settingsPage1.Page);
                                      protected override bool OnSettingChange(string pageId, AbstractView currentView, AbstractView changedView)
                                          Console.WriteLine("OnSettingChange");
                                          if (changedView.Id == "idtxtMakerAPIURL") _settings.MakerURI = changedView.GetStringValue();
                                          else if (changedView.Id == "idtxtLocation") _settings.Location = changedView.GetStringValue();
                                          if (changedView.Id == "idtxtLocation2") _settings.Location2 = changedView.GetStringValue();
                                          else if (changedView.Id == "idchkDebug") _settings.DebugLog = (changedView.GetStringValue() == "True");
                                          return true;
