Submittal of HS4 plugins
    I have finished development of what amounts to a new HS4 plugin and tested vs x.30 Alpha. What do I do with it now?
    The plugin portal is operational for HS4 plugins so go to plugins.homeseer.com and submit it there. Same process as HS3 plugins.
      I would like to evaluate via updater_override.txt before I submit to store. My file was created using the SDK info from HS3 which is below.
      'Name, Updater version, File version, Notices version
      HomeSeer Updates File, 3.0.0.0, 14, 1
      .,anonymous,user@updates,.,,,0.0.0.0
      '%<HS TYPE=SUBCAT>Updates
      '%<HS TYPE=SUBCAT>Local Updates
      mcsHubitat,HSPI_mcsHubitat.exe,,4.0.7.0,63,2,local,ZIPS,mcsHubitat_4.0.7.0.zip,4,Free,Michael McSharry,Hubitat Eevation,http://mcsSprinklers.com/hubitat.png,http://mcsSprinklers.com/HSupdater_mcsSprinklers.htm,0085,https://shop.homeseer.com/products/mcssprinkler-plug-in-professional-for-hs3
      The HS3 instructions indicate that I should use the Update Listing button. I do not see a Update Listing button when only HS4 plugins are available. If I put a HS3 plugin in HS4 folder then I get a Manage button for the HS3 plugin and it will show an Update Listing button. When I click it, it shows the local interfaces including the HS4 I want to evaluate. I click Download and Install and nothing happens.
        Others have asked about this also. The procedure you note is for HS3 plugins. The HS4 updater file is now a JSON formatted file. Let me get this working and I will post new instructions.
          rjh Any update on this. It would be good to locally test plugins first.
          Greig.
          Scripts =
          Various
            Yes, its in there now, here are the docs:
            https://docs.homeseer.com/display/HS...g+Installation
              Perfect thanks.
              Greig.
              Sent from my SM-G973F using Tapatalk
              Scripts =
              Various
