What is plug-in tab header doing in feature edit
    When I observe from Device Tile a feature I obtain a tab with the plug-in name that likely created the feature. What is suppose to show on that tab? Is there something that the plug-in should be doing to support that tab?
    Michael,
    That is the same tab as shown in HS3. Here you can set extra options related to the item for the plugin. Here is the HS3 equivalent:
    Click image for larger version  Name:	2020-02-08 22_30_59-Modify Huiskamer JowiHue ....png Views:	0 Size:	233.6 KB ID:	1360813
    You enable showing the configuration option with https://docs.homeseer.com/display/HS...evice+Property
    You can fill the page by overriding https://docs.homeseer.com/display/HS...figPage+Method
    Bit late here, but I hope this gets you on track.
    Wim
    -- Wim
      Thanks wim. If it was a new design I may have used it, but at least now I will know how to disable it.
        It lost a lot of its functionality. As it does not enable using your own button texts, or other options I am also using it hardly anymore
        -- Wim
