Error with sample plugin
    Hi,
    I started with the sample plugin, but I get an exception when I start the plugin.
    No error during build or HS4 start
    Using the latest version of it all (HS4, pluginsdk and plugin sample)
    System.IO.FileNotFoundException
    HResult=0x80070002
    Message=Could not load file or assembly 'PluginSdk, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
    Source=<Cannot evaluate the exception source>
    StackTrace:
    <Cannot evaluate the exception stack trace>
    Rien du Pre
    The Netherlands
    Using:
    Homeseer PRO latest HS4 BETA on a Raspberry
    Plugin's:
    RFXCOM, mcsMQTT, Z-Wave
    Rien,
    You will have to get the nuget packages for the plugnSDK and Newtonsoft first before that part will work.
    Wim
    -- Wim
      Hi Wim,
      I’m pretty sure I did that. The project does build without errors
      Rien du Pre
      The Netherlands
      Using:
      Plugin's:
        Rien,
        Are you running the plugin complied, based on the HS4 installation, or from VS tracing? If you run it compiled from the HS4 directory, make sure you have a config file pointing to the Plugins bin directory, but it also has to include bin/homeseer as that is where the PluginSDK resides?
        -- Wim
          Sorry for the late reaction, I solved it with a config file.
          I thought these files will be created during the process, but apparently not.
          Thanks Wim
          Rien du Pre
          The Netherlands
          Using:
          Plugin's:
