How to save/commit feature changes?
  • stefxx
    Again, thank for the help! Here is some code from my plugin to test/replicate the issue. As I copied some stuff and put everything in 1 sub it might not be the best or most optimized code, but it does show the issue. Perhaps you can copy this in your plugin and run the "Test" sub?
        Sub test()
            ' Create the device
            Dim df As DeviceFactory = DeviceFactory.CreateDevice(PI_Id)
            df.WithName("Device")
            df.AsType(Identification.EDeviceType.Generic, 0)
            Dim ndd As NewDeviceData = df.PrepareForHs()
            Dim dv As HsDevice = GetDeviceByRef(hs.CreateDevice(ndd))
            dv.Interface() = PI_Id
            dv.Address() = "Device"
            hs.UpdateDeviceByRef(dv.Ref, dv.Changes)
            ' Create some features
            For i = 1 To 5
                Dim ff As FeatureFactory = FeatureFactory.CreateFeature(PI_Id)
                ff.WithName("Feature " & i)
                ff.WithLocation(dv.Location)
                ff.WithLocation2(dv.Location2)
                ff.AsType(Identification.EFeatureType.Generic, 0)
                Dim nfd As NewFeatureData = ff.PrepareForHsDevice(dv.Ref)
                Dim dvf As HsFeature = hs.GetFeatureByRef(hs.CreateFeatureForDevice(nfd))
                hs.UpdatePropertyByRef(dvf.Ref, EProperty.Interface, PI_Id)
                hs.UpdatePropertyByRef(dvf.Ref, EProperty.Address, "Feature" & i)
                ' Add Graphics range
                Dim StatusGraphic As StatusGraphic = New StatusGraphic("/images/HomeSeer/status/nostatus.gif", 0)
                StatusGraphic.IsRange = True
                StatusGraphic.RangeMin = 0
                StatusGraphic.RangeMax = 10
                hs.AddStatusGraphicToFeature(dvf.Ref, StatusGraphic)
            Next
            ' Update features
            For i = 1 To 5
                Dim dvf As HsFeature = hs.GetFeatureByAddress("Feature" & i)
                hs.UpdateFeatureValueByRef(dvf.Ref, i) ' This works fine
                hs.UpdatePropertyByRef(dvf.Ref, EProperty.Status, "New status " & i) ' This does not work except for the last feature
                dvf = hs.GetFeatureByRef(dvf.Ref) ' rereading the hsfeature doesn't seem to have any effect
                'hs.UpdateFeatureByRef(dvf.Ref, dvf.Changes) ' NO VERSION error
            Next
        End Sub
    This is the result. Only the status of the last feature is saved.
Name:	Annotation 2020-03-21 051656.png
    BTW, I know that when I use UpdateFeatureStatusByRef instead it will work, but then the issue persists for other properties.
  • w.vuyk
    Originally posted by stefxx View Post
    If seems to happen when I update several devices quickly after each other. If I update the hsfeature first, it seems to work. Like this:
    feature.Status = "Whatever"
    UpdatePropertyByRef(feature.ref, EProperty.Status, "Whatever")
    If this remains stable, I leave it for now until someone from HomeSeer gives us a better way.
    Stef,
    Did you try as I did? First use the UpdatePropertyByRef, then reread the feature with GetFeatureByRef. This should get you the just updated Feature. What you were doing is adding an update to the changes object, like Dirk was mentioning. And indeed, this is just as buggy as UpdateFeatureByRef , throwing very vague errors that does not explain anything.
    Wim
  • dcorsus
    Confusing as heck, I know, but to update the status I use:
    UpdateFeatureValueStringByRef(FeatureRef, NewValue.ToString)
    For most other things I use UpdatePropertyByReference
    Updating featureByRef with a feature object I just retrieved, update a field and subsequently use feature.changes doesn't work. In fact, if I retrieve a feature from HS and I inspect the property "Changes", it pretty much shows all attributes as "changed". I'm only assuming what this property "changes" is supposed to do, but retrieving it from HS seems to SET all attributes of the instantiated object as "changed" and therefore if you now use it to do an UpdateFeatureByRef and use feature.changes in many cases it will fail because not all properties can be changed that way.
  • stefxx
    Never mind, it still doesn't work.
  • stefxx
  • w.vuyk
    Stef,
    I have it working this way here, no separate saving needed? Wonder why it would not work. As far I can remember I did not do anything else.....
  • stefxx
    Thanks, that is clear. However, it doesn't solve my issue.
    If I update several devices like this, most of it doesn't get saved. Especially setting the Device Status gets lost.
  • w.vuyk
    Stef,
    It is really simple what I am doing here, just a block of updates and - when needed - a reread of the object to make sure changes are reflected again in the object:
    HS.UpdatePropertyByRef(ref, Devices.EProperty.DeviceType, DT)
    HS.UpdatePropertyByRef(ref, Devices.EProperty.PlugExtraData, PED)
    HS.UpdatePropertyByRef(ref, Devices.EProperty.Address, If(IsLight, lightrow.Uniqueid & "-L", grouprow.Uniqueid & "-L"))
    HsFeature=HS.GetFeatureByRef(ref)
    Wim
  • stefxx
    Thanks for your response Wim! What do you mean by "rereading the HsFeature again"? Do you have an example of how it works for you?
    Thanks again!
  • w.vuyk
    Steffxx,
    The hs.UpdateFeatureByRef Is very, very buggy. It throws NO VERSION errors for almost every update here. I am only using UpdatePropertyByRef here now. It needs rereading the HSFeature again, as this is a more static representation of the moment you read it - it is not dynamic. So I combine both and it then works reliable. But it is wasting cycles for sure..
    Wim
  • stefxx
    started a topic How to save/commit feature changes?
    I am confused. I know that I can update a value by using UpdateFeatureValueByRef(feature.ref). However, when updating other fields (like name) it should be done by using UpdatePropertyByRef(feature.ref, EProperty.Name, "Whatever"). But this doesn't get saved automatically.
    I tried hs.UpdateFeatureByRef(feature.Ref, feature.Changes) but that is giving me a "'Invalid type for property Service Version: NO_VERSION' error.
    Any help is appreciated! Thanks!
