To debug in HS3, I connect to a remote server. I've always passed along "server=192.168.1.xxx" in the command line. I am tinkering with one of the HS4 sample plugins and this appears to no longer work. I would appreciate help in resolving my issue.
Command Line Arguments - Remote Server
I did this when I first started with HS4, but been too long and don’t have remnants. What I think you need to do is overload the abstract plugin Connect method and pass the parameter at that point. I always hard coded the IP when I was testing so did not actually parse command line. Worth a try.
If I remember correctly when the plugin connects the HS4 prints something like server = xxxx which implies there is some logic that it is using to get the remote IP.
The IP address for the Abstract Plugin is a protected property. Not an ideal way to do it but I simply added the address to my HSPI() constructor right under LogDebug property. Obviously the IP address is the remote HS4 server. I am hoping at some point HS will make it a public attribute again.
Code:public HSPI() { //Initialize the plugin //Enable internal debug logging to console LogDebug = true; //Setup anything that needs to be configured before a connection to HomeSeer is established // like initializing the starting state of anything needed for the operation of the plugin //Such as initializing the settings pages presented to the user (currently saved state is loaded later) [COLOR=#B22222][B] IpAddress = "192.168.12.174";[/B][/COLOR] InitializeSettingsPages(); //Or adding an event action or trigger type definition to the list of types supported by your plugin ActionTypes.AddActionType(typeof(WriteLogSampleActionType)); TriggerTypes.AddTriggerType(typeof(SampleTriggerType)); }
James
Running HS 3 on Win10 .
