Is there an equivalent to HS3's hs.SystemUpTime() function?
System uptime
I hacked this up by reading Logs/Startup.hsd. Would be nice if there were an official function though.Code:Private Function SystemStartTime() As DateTime Dim StartupLog As System.IO.StreamReader = My.Computer.FileSystem.OpenTextFileReader("Logs/Startup.log") Dim FirstLogEntry As String = StartupLog.ReadLine StartupLog.Close() Dim LogElements As String() = FirstLogEntry.Split(" ") If LogElements.Count > 2 Then Return Convert.ToDateTime(LogElements(0) & " " & LogElements(1) & " " & LogElements(2)) End If Return Convert.ToDateTime("1/1/2020 00:00:00") End Function Public Function SystemUpTime() As String Dim TS As TimeSpan = SystemUpTimeTS() Return TS.Days.ToString & " Days " & TS.Hours.ToString & ":" & TS.Minutes.ToString.PadLeft(2, "0") & ":" & TS.Seconds.ToString.PadLeft(2, "0") End Function Public Function SystemUpTimeTS() As TimeSpan Return Now.Subtract(SystemStartTime) End Function
