I do not know if it is related but I just ran into this issue today. Still trying to figure it out.
Error opening com port: Access to the port 'COM3' is denied. Trace: at System.IO.Ports.InternalResources.WinIOError(Int32 errorCode, String str)
at System.IO.Ports.SerialStream..ctor(String portName, Int32 baudRate, Parity parity, Int32 dataBits, StopBits stopBits, Int32 readTimeout, Int32 writeTimeout, Handshake handshake, Boolean dtrEnable, Boolean rtsEnable, Boolean discardNull, Byte parityReplace)
at System.IO.Ports.SerialPort.Open()
at HSPI_ZWave.ZWaveAPI.RThreadProc_Serial()
Error: Home Ctl: Cannot open COM port COM3, exiting. Ex=Access to the port 'COM3' is denied.
Error: Home Ctl: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxx
Error: Home Ctl: Cannot open COM port COM3: Access to the port 'COM3' is denied.
Z-wave plug-in not initializing
I disabled the two z-nets in the plug-in and setup a Aeotec Z-stick just to test things.
However, I now get a fatal error. Anyone else?
I know about dev.homeseer.com but I don't like it, I'll post here knowing they'll eventually see it.
Log info:
Initializing plug-in(1): Z-Wave Instance::Error registering web pages with the HomeSeer server: Object reference not set to an instance of an object.
Service Version: NO_VERSION->
Server stack trace:
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessag e(IMessage reqMsg, IMessage retMsg)
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type)
at HomeSeerAPI.IHSApplication.RegisterPage(String pageName, String PluginName, String PluginInstance)
at HSPI_ZWave.HSPI.InitIO(String port) Time to load: 1401 millisecondsTags: None
