What is HS4 equivalent of hs.CAPIControlHandler(CAPIcontrol)
  • spud
    SendControlForFeaturebyString is now available in PluginSdk 1.3.0.0 and HS 4.1.17.0
    https://homeseer.github.io/Plugin-SD...atureByString_
  • Michael McSharry
    Thanks spud
  • spud
    spud
    that would be a reasonable addition to match the ControlString that exists in ControlEvent
    it seems users should also have the capability in Event Actions to command a String. in both HS3 and HS4 the control device appears to only control Value.
    I added a feature request for SendControlForFeatureByString
  • tenholde
    IHsController.SendControlForFeatureByValue
    https://homeseer.github.io/Plugin-SD...System_Double_
    So, will these IHsController methods be available to scripting running from an event?
  • Michael McSharry
    spud
  • alexbk66
    I'm not the one who wrote the SDK, so I'm not sure about the rationale behind all the design choices.
    The SDK is open source so if you think something should be implemented differently, pull requests are welcomed.
    I know, I know
  • spud
    This implies to me that features can only be controlled with numbers. In hubitat plugin, for example, devices can be controlled by text (e.g. Speak something). How is it done with HS4? What I have done is a kludge by first setting the string and then commanding a number and the plugin's handler then looks at the string to see what should be spoken.
    Should this method be included in https://docs.homeseer.com/pages/view...pageId=7443557
    so basically, you need a SendControlForFeatureByString(int devOrFeatRef, string value) method to be added?
  • spud
    Originally posted by alexbk66 View Post
    Just wondering, since you are creating a new library, why not do it proper OOP way? I.e. instead of IHsController.SendControlForFeatureByValue(device) - do device.SendControlForFeatureByValue()
  • Michael McSharry
  • alexbk66
  • spud
  • What is HS4 equivalent of hs.CAPIControlHandler(CAPIcontrol)
    Look in the object model and in the API HS3->HS4 reference and did not have any hits?
    How does one command another plugin's feature?
