can we rebuild/dynamically change a settings page based on user input? for example, after a user enters a value, and clicks save, rebuild the page, and redisplay
can we dynamically change a SettingsPage using CreateSettingsPage
Mark
HS3 Pro 3.0.0.534
Hardware: Insteon Serial PLM | AD2USB for Vista Alarm | HAI Omnistat2 | 1-Wire HA7E | RFXrec433 | Dahua Cameras | LiftMaster Internet Gateway
Plugins: Insteon (mine) | Vista Alarm (mine) | Omnistat 3 (by Kirby) | Ultra1Wire3 | RFXCOM | NetCAM | MyQ | BLRadar | BLDenon | Jon00 Charting
Platform: HP h8-1360t, Windows Server 2012 R2, i7-3.4GHz, 16GB memoryTags: None
I wanted something similar early on, but in the brief time I fooled with SettingsPage, there's just limited functionality.
For example, I wanted the user to enter something like an IP, username, and password. From there, I wanted the page to validate that info and return something back. I could not figure it out.
Subscribing to see if this is possible...HS4Pro Running on a Raspberry Pi4
67 Z-Wave Nodes, 111 Events, 422 Devices
Z-Wave, UPB, WiFi
Plugins: EasyTrigger, weatherXML, OMNI, Z-Wave, Tuya, Device History
within the OnSettingChange, based on my logic, i called Settings.RemoveAll() and then called my routine to rebuild the Settings page. Based on the new logic the settings page are changed and registered to the plugin menu.
i don't know if this is a good idea or supported, but at first glance it seems to work.Mark
HS3 Pro 3.0.0.534
Thats good info... Are you able to rearrange anything on the SettingsPage when you rebuild it?HS4Pro Running on a Raspberry Pi4
Z-Wave, UPB, WiFi
Originally posted by rmasonjr View PostThats good info... Are you able to rearrange anything on the SettingsPage when you rebuild it?
i have two setting pages (basic & advanced): on the basic page, i add a username/pswd field based on the input value of the first field and Save. on the advanced. i completely change a few settings on the advanced page as well.
Mark
HS3 Pro 3.0.0.534
- Likes 1
