Imports 'System.Core' doesn't contain any public member or cannot be found
    I thought this used to work.
    Any ideas?
    Compiling script tempdiff.vb: Namespace or type specified in the Imports 'System.Core' doesn't contain any public member or cannot be found. Make sure the namespace or the type is defined and contains at least one public member. Make sure the imported element name doesn't use any aliases.
    Sub Main(ByVal Parm As Object)
    Dim outtemp as string
    Dim intemp as string
    Dim diff as string
    Dim tempdiffswitch as string
    Dim tempdiff as string
    Try
    hs.WriteLog("Info","Starting Temp Difference B")
    tempdiffswitch = hs.GetDeviceRefByName("Temperature Difference")
    tempdiff = hs.GetDeviceRefByName("Utility Weather tempdiff")
    outtemp = hs.GetDeviceRefByName("Outdoor Temperature")
    hs.WriteLog("Info","outtemp ID: "& outtemp)
    hs.WriteLog("Info","outtemp: "& hs.deviceValue(outtemp))
    intemp = hs.GetDeviceRefByName("Kitchen Motion - Temperature")
    hs.WriteLog("Info","intemp ID: "& intemp)
    hs.WriteLog("Info","intemp: "& hs.deviceValue(intemp) )
    diff = hs.deviceValue(intemp) - hs.deviceValue(outtemp)
    hs.WriteLog("Info","diff: "& diff)
    hs.SetDeviceValueByRef(tempdiff, diff, True)
    if diff > 3 then
    hs.WriteLog("Info","switch ON ")
    hs.SetDeviceValueByRef(tempdiffswitch, 100, True)
    hs.setDeviceString(tempdiffswitch,"100",True)
    else
    hs.WriteLog("Info","switch OFF ")
    hs.SetDeviceValueByRef(tempdiffswitch, 0, True)
    hs.setDeviceString(tempdiffswitch,"0",True)
    end if
    hs.WriteLog("Info","Starting Temp Difference B 100")
    Catch ex As Exception : hs.writelog("", "Exception: " & ex.message)
    End Try
    End Sub
    Change the writelog("a","b") in writelogex("a","b", "") and see it is solving the error? The last parameter can be a colorcode.
    Wim
    -- Wim
      Stripped everything. See errors below:
      Sub Main(ByVal str0 As String)
      Dim diff as string
      End Sub
      Time
      From
      Type
      Message
      7/24/2020 13:45:12
      HomeSeer
      Error
      Compiling script tempdiff.vb: 'intemp' is not declared. It may be inaccessible due to its protection level.
      7/24/2020 13:45:12
      HomeSeer
      Error
      Compiling script tempdiff.vb: 'outtemp' is not declared. It may be inaccessible due to its protection level.
      7/24/2020 13:45:12
      HomeSeer
      Error
      7/24/2020 13:45:11
      HomeSeer
      Event
      Running
        Something weird happening here. I changed the name of the vars and it still has the old script loaded.
          That should be dynamic, but never tested this with HS4 yet. Still slowly moving to HS4. On the other hand, the catch is called now, so I guess the writelogex change is working now. Nothing else changed?
          -- Wim
            It's not reading the script. I tore the actual script down and only have the vars. I also renamed the vars but it still refers to the old var.
            So first thing is finding out why it's not reading the script
              Did you ever solve this? I have the same kind of migration problem.
