Plugin versions in HS4 updater
    I couldn't find a better place in the forum to ask this.
    Regarding the plugin versions:
    1. The currently installed version and update version (if available) should be displayed in the updater (like it was in HS3 updater)
    2. If update is available - the new version should be also shown on the Installed plugins management page - with "Update" button.
    Yes this is confusing the way it is now on hs4.
      It's not just confusing - it's totally user unfriendly.
        Although HS4 runs fine, I have only found one user friendly feature. That's the ability to enable/disable individual actions in an event.
        Everything else is less user friendly IMO.
          Anyone know if there's a plan to fix this back to HS3 levels of information? Knowing if the plugin is up to date is the first thing I do if I'm trying to understand a problem.
            At least, there's an "update" icon when update is available.
            https://dev.homeseer.com/servicedesk...al/2/HSCS-4313
              That's something. I didn't know such an icon existed. Maybe its existence is in the manual, but it wasn't obvious from the page.
                That's because that indicator rarely appears. Rupp conceded they aren't working on quick little things bugs like this - not that the bigger ones seem to be progressing either
                What the actual?!? When I make a sarcastic remark or joke it is moderated/deleted.
                But you specifically go out of your way to label multiple HS4 issues that cause data loss/crash of HS4 to be "grumbles".
                I can't even begin to put into words how offensive this is.
