When I try AKGoogleCalendar on HS4 Linux (Ubuntu 20.04) - I get lots of nasty errors in the terminal window. Plugin still seem to work, but I can't ignore stack overflow errors.
JLDubz?
[EDIT 1]
FYI, mono-vbnc is installed
[EDIT 2]
There's quite a few threads about this error in the forum - no single reply from HST!
macromark and spud are mentioned directly in one of them.
https://forums.homeseer.com/forum/hs...hs-pro-4_0_5_0
https://forums.homeseer.com/forum/ho...e-field-issues
https://forums.homeseer.com/forum/hs...-after-linking
https://forums.homeseer.com/forum/ho...stack-overflow
https://forums.homeseer.com/forum/li...-control/page2
Error in device_prop: The requested operation caused a stack overflow. Error in device_misc: The requested operation caused a stack overflow.
[EDIT 1]
[EDIT 2]
