Adding Category to a device
    I'm using the following code to add an existing category to a device using its reference ID:
    Sub Main(Parm As Object)
        Dim Ref As Integer = 1234
        hs4.AddRefToCategory("Fans",Ref)
    End sub
    When run, no errors but the 'Fan' is not added to the device category list when you inspect its device settings?
    Is this a bug or am I doing this wrong?
    Jon
    Does category exist? You need CreateCategory() first.
Name:	Screenshot 2022-07-28 232927.png
      As stated this is an existing category (default categories provided by HomeSeer)
      Jon
        And BTW, there was a bug that you can add the same ref to the list, hence refs.Contains(RefId) check.
          I believe that the first argument is not the name/alias of the category but the CategoryID of the Category.
          tenholde
            Ahh...yes. Misread the docs. I can get the GUID using hs4.GetAllCategories() and extracting the Key.
            Thanks for the pointer!
            Jon
              Yeah,
Name:	Screenshot 2022-08-03 003336.png
