ConvertLegacyData
    ConvertLegacyData
    How do you remove the legacy trigger(and actions) after calling ConvertLegacyData?
    I finally got ConvertLegacyData working to convert my legacy trigger to the new AbstractTriggerType - works great.
    How do you remove the old inData after it is converted so that it does not get re-converted over and over and over ?
    I feel like there should be something to remove that data after it is converted?
    Rob
    72 Z-Wave Nodes, 111 Events, 422 Devices
    Z-Wave, UPB, WiFi
    Plugins: EasyTrigger, weatherXML, OMNI, Z-Wave, Tuya, Device History
    I use hs4.UpdatePlugTriggerallow and hs4.UpdatePlugAction to revise the trigger and action data so it no longer looks like a legacy trigger or event data
    i then check the datain.length < 500. hs3 datain is much shorter than hs4 datain. i guess this is a hack, but seems to work for my purposes.
    edit: i dont actually have code for the ConvertLegacyData method. i have my own that is one time use: MyConvertLegacyData
    Mark
    HS3 Pro 3.0.0.534
      [deleted]
        https://github.com/HomeSeer/Plugin-S...ment-595481935
        Looking at the Lifecycle of a Trigger you can see that the trigger is not saved to the HS database until after a call to OnConfigItemUpdate() returns true or a call to IsFullyConfigured() returns true. If you are just clicking the edit button on a trigger and not clicking the save button, the underlying TrigActData saved in the HS database will not be updated.
          The UpdatePlugTrigger was added to IHsController
Name:	Screenshot 2022-07-30 112606.png
