How to replace a " ° " character in a vb script ?
    I am trying to build a specific weather forecast phrase to be sopken out of Sonos from different "Environment Canada" weather plugin devices.
    The problem I am having is I have a specific device string that contains the " ° " caracter that i would like to replace by "Degré Celcius" but I can't find a way for the Replace function to detect and replace this specific caracter.
    Here's an exemple that I am using for many other caracters and words replacement: ResSommaire = Replace(ResSommaire ,"05h00","à cinq heure. ") and this works fine but if iI try the below line (where DevTemp is 7.7°C)
    ResTemp = Replace(DevTemp,"°C"," degré celsius")
    the results of ResTemp is always 7.7°C and not 7.7 degré celsius as I would expect it to be
    Any idea ?
    thanks
    You could try: ResTemp = Replace( DevTemp, Chr(176), " degré celsius")
      Uncle Michael Unfortunatly, your solution gives the same results, the " ° " caracter is still not recognised by the replace function with chr(176), thanks for the try
        You need to examine the actual device string code as it may contain html code for the degree symbol. If you have my device viewer & documenter installed, you can use the advanced view to see the string (code) being used.
        Example below:
        Click image for larger version  Name:	Capture.PNG Views:	0 Size:	40.3 KB ID:	1505645
        Alternatively, you can right-click on the web page and select 'view source' and try to find it there.
        Jon
          jon00 I just tried the device viewer utility and there does not seem to be any HTML:
          I guess I need to find a way to enter ResTemp = Replace(DevTemp,"°C"," degré celsius") in the script but if I enter this line in the script editor, the editor immediatly change the ° by " ° "
            ° is the html code for the character °
            You will need to use a standard text editor rather than Homeseer's which is limited.
            Jon
              jon00 thank you so much, I edited the file with Note entered ResTemp = Replace(DevTemp,"°C"," degré celsius") and now it works.
                Just remember NOT to open it in Homeseer's editor or it will be modified!
                Jon
                  What about using this instead ℃
                  it’s the actual degree C symbol
                  HTML code is
                  &#8451
                  You have to add a ; after the code above.
                  Roger D
