Hs.writeLog command errors
    #31
    $n works because its using the vb.net engine to run the script which supports overloaded functions. The other syntax causes the old vbscript COM engine to be used. We overloaded the writelog function and I suspect the developer who did that did not realize the limitations of vbscript. The only fix is to remove the overloaded function which might break other scripts or plugins that also use that API.
    Yes, I can add a note to the docs. We are in the process or moving all the scripting docs to a new format.
    Originally posted by jon00 View Post
    Rich,
    I don't wish to be a pain, but would you please elaborate on this? Which API are you referring to? If this is going to be the case, should not this be documented somewhere?
    Just for your information, the following works in an immediate script command:
    &nhs.Writelog ("WriteLog Entry", "Insert message here")
    This fails:
    &hs.Writelog ("WriteLog Entry", "Insert message here")
    Running script(1) &hs.Writelog ("WriteLog Entry", "Insert message here"), init error: Cannot use parentheses when calling a Sub
    As does:
    &hs.Writelog "WriteLog Entry", "Insert message here"
    Running script(2) &hs.writelog WriteLog Entry, Insert message here, init error: Syntax error
      #32
      Ok, fully understand the issue. One option may be to try $nhs on &hs error; however it is probably easier to say that implement.
      Jon
        #33
        I'm still confused because this works on my RPi HS4 4.1.16.0 system.
Name:	Screenshot from 2021-05-18 20-10-03.png
Name:	Screenshot from 2021-05-18 20-12-21.png
        Roger D
          #34
          Forgot to ask...
          What does the "n" in &nhs. do?
          Roger D
            #35
            Originally posted by Roger D View Post
            Forgot to ask... What does the "n" in &nhs. do?
            These prefixes tell what script engine to use, i.e. default VB, VB.NET ('n') or C# ('s' or 'c' - can't remember).
            Took me awhile to work out, just wondering if it's documented somewhere rjh spud?
              #36
              Documented here:
              https://docs.homeseer.com/display/HS...ipt+Statements
              Originally posted by alexbk66 View Post
              These prefixes tell what script engine to use, i.e. default VB, VB.NT ('n') or C# ('s' or 'c' - can't remember).
                #37
                The PI (and Linux in general) does not support VBScript, you only have vb.net scripting, so not an issue on those systems.
                Roger D
