$n works because its using the vb.net engine to run the script which supports overloaded functions. The other syntax causes the old vbscript COM engine to be used. We overloaded the writelog function and I suspect the developer who did that did not realize the limitations of vbscript. The only fix is to remove the overloaded function which might break other scripts or plugins that also use that API.
Yes, I can add a note to the docs. We are in the process or moving all the scripting docs to a new format.
Originally posted by jon00
View Post
