Hi All,
This simple script should read a value from one device (2322) and set that value to another device (name of Fitness Euro TRV setpoint").
Public Sub Main(ByVal Parm As String)
hs.WriteLog("Info", "Starting...")
Dim devVal = hs.DeviceValue(2322) 'This is the Secure Thermostat set temperature
hs.WriteLog("Info", "Fitness thermostat set temperature is:" & devVal)
hs.SetDeviceValueByName("Fitness Euro TRV setpoint", devVal) 'This is my destination TRV
hs.WriteLog("Info", "Finished! TRV is set")
End Sub
It seems to work but not as I expect.
When it runs, I can see the value of the destination device change correctly from the HS4 UI. However, the destination physical device does not actually change.
It seems that the software device in the HomeSeer interface is correctly set but I then need to press the "SUBMIT" button on the HS4 UI before the physical device receives the instruction.
What am I missing?
Thanks guys
PS I have got it an alternative solution using device "Association" - but I thought this script should work.
End Sub
What am I missing?
Thanks guys
