HS4 Scripting Extension (by ten)
    A library of a few script extensions callable from any script that might be useful for some. http://tenholder.net/tenWare2/Script.../Overview.aspx
    Note:  [I]tenScripting4 [/I]now makes it easy for you to develop your own Global Methods, callable from ANY HS4 script.
    [URL]http://tenholder.net/tenWare2/tenScripting4/GlobalMethods.aspx[/URL]
    You can turn ON all devices that are in both Categories Lights and Office with just:
    Dim Result = DeviceOn(hs, GetRefsInBothLists(GetRefsByCategoryName(hs4, "Office"), GetRefsByCategoryName(hs4, "Lights")))
    Here are a few of the extensions:
    DeviceOn(hs, DevRef as Integer) as String
    DeviceOn(hs, DevRefs as List(Of Integer) as String
    DeviceOff(hs, DevRef as Integer) as String
    DeviceOff(hs, DevRefs as List(Of Integer) as String
    ToggleDeviceOnOff(hs, DevRef as Integer) as String
    GetCategoriesByRef(hs4, DevRef as Integer) as List(Of String)
    GetRefsByCategoryName(hs4, CatName as String) as List(Of Integer)
    tenholde
    Sweet! Thanks for another innovative piece of software!
      First of all I want to say thanks for the HS4 script extension.
      I need help with the script extension for GetFeatureRefByFullname() in vb script?
      Must I include Floor and Room name for the Feature name? Any way I can get the feature ref id by just specifying the device name and its feature name?
        Need floor and room for both device and feature. Even then, the combination is not always unique. tenScriptAid4 will detect and report all duplicates
        tenholde
          Check misc tab on tenScriptAid4
          While GetFeatureRefByFullname would need the fully qualified Device (root) name, I could modify it to optionally just look for the Name of the feature. Let me know if this would be helpful.
          tenholde
            Hi tenholde,
            Thanks for replying to my question.
            Yes it would be helpful. With HS4 now I have changed all my devices name + features name to be unique. The room and floor is mainly used to categorize it.
              Hi Tenholder,
              I'm using your .dll to GetFeatureRefByFullname() and turning ZigbeePlus device on of off with DeviceON() DeviceOFF()
              Is there also a way to SET feature values/strings within a .vb script.
              If not can you add extentions to set features just like DeviceOn?
              Hans
                No need for additional extensions. Get DevRef by FullName and then use standard scripting references, such as:
                Dim DevRef As Integer
                DevRef = GetFeatureRefByFullname(hs, "tenPlugin tenBrultech House", "tenPlugin tenBrultech House TriggerHigh")
                hs4.UpdatePropertyByRef(DevRef, EProperty.Value, 37) 'set device value
                hs4.UpdatePropertyByRef(DevRef, EProperty.StatusString, "High Trigger is 37") 'set device string​
                tenholde
                  Thanks for your answer.
                  How to use this in a .vb script. I'm getting 'Eproperty' is not declared.
                  Do I need to import something?
                  Hans
                    Try:
                    hs4.UpdatePropertyByRef(DevRef, HomeSeer.PluginSdk.Devices.EProperty.Value, 37) 'set device value
                    tenholde
                      Try:
                      Still not working...
                      I get this eror in the logfile:
                      Error 00 Running script: Exception has been thrown by the target of an invocation
                      This is my script:
                      Imports System.IO
                      Imports System.Net
                      Imports tenGlobalMethods
                      Imports System.Collections.Generic
                      Imports System.Threading
                      Sub Main()
                      DevRef = GetFeatureRefByFullname(hs, "Plugin Zigbeeplus Lamp-4", "Plugin Zigbeeplus Brightness")
                      hs4.UpdatePropertyByRef(DevRef, HomeSeer.PluginSdk.Devices.EProperty.Value, 37) 'set device value​
                      End Sub
                        Try:
                        ​​​​Public Sub Main(parms as Object)
                        tenholde
                          Try:
                          That makes no difference.
                          Setting value is NOT working
                          hs4.UpdatePropertyByRef(DevRef, HomeSeer.PluginSdk.Devices.EProperty.Value, 78) 'set device value​
                          But, setting statustring IS working without error's (Checked the settings with tenScriptAid
                          hs4.UpdatePropertyByRef(DevRef, HomeSeer.PluginSdk.Devices.EProperty.StatusString, "78 %") 'set device string
                          Any idea why the value gives the error?
Name:	Screenshot 2023-07-24 191442.png
                            Did the error go away?
                            tenholde
                              No, see pervious post 13 .Value gives a error .Statusstring is ok
