I apologize in advance because this issue is so simple, it must be elsewhere on the forums, but I can't find it.
I have a Centralite thermostat which is not yet supported in Homeseer so it is still connected to my old SmartThings system and being presented in Homeseer via the SmartThings plugin.
I want to add Increment and Decrement setpoint functionality so I can use up/down buttons in HS4Touch.
The script below runs and thinks it is incrementing the setpoint, but the setpoint on the device never actually changes.
Is there an extra step that I need to go through to send the change back through the plugin?
I appreciate any suggestions.
TIA
Sub IncrementSetpoint(parms As Object) Dim CurrentValue, NewValue, SetpointRef If hs.DeviceValueByName("Thermostat Mode") = 5 'Heat hs.WriteLog("Info", "Thermostat Mode is Heat") SetpointRef = hs.GetDeviceRefByName("Thermostat Heating Setpoint") Elseif hs.DeviceValueByName("Thermostat Mode") = 1 'Cool SetpointRef= hs.GetDeviceRefByName("Thermostat Cooling Setpoint") End If CurrentValue = hs.DeviceValue(SetpointRef) NewValue = CurrentValue + 1 hs.WriteLog("Info", "Current Value: "&CStr(CurrentValue)&", NewValue: "&CStr(NewValue)) hs.SetDeviceValueByRef(SetpointRef, NewValue, FALSE) CurrentValue = hs.DeviceValue(SetpointRef) hs.WriteLog("Info", "FinalValue: "&CStr(CurrentValue)) End Sub​
