alexbk66 sorry, I was confused about fuslogwv.exe because it comes with the MS SDKs.
I suspect that I don't see anything in fuslogwv.exe because my script never gets to the point of running. The problem is that HS doesn't even finish compiling the script as seen in my post Albums
- I am running it in admin mode (right click, run as administrator).
- I have exactly the same setting and c:\temp is a directory that exists (see screenshot below)
- I close the settings dialog box before proceeding
- I then run my event that calls the script.
- I then go to the HS log file to see I still get the compiler error, which I do.
- I then go back to fuslogwv.exe and hit "Refresh" but nothing shows up. Not log file is written to c:\temp, either.
