Test page source code
  • Test page source code
    Does anybody have the source code for localhost/test page?
    In the developers webinar 21 Dec 2012 the HS developer promiced to post the source code for the page to show how to use clsJQuery controls:
    Click image for larger version  Name:	2018-11-15 (1).png Views:	3 Size:	61.0 KB ID:	1259543
    HTML Code:
    <%@ Page Language="VB" %>
    <script runat="server">
        ' Insert page code here
        Dim hs As Scheduler.hsapplication
        Dim plugin As HomeSeerAPI.PluginAccess
        Sub Page_Load(Sender As Object, E As EventArgs)
            ' for use with the HS web server
            hs = Context.Items("Content")
            ' get a reference to the Z-Wave plugin
            plugin = New HomeSeerAPI.PluginAccess(hs, "Z-Wave", "")
            If plugin.Connected Then
                Label2.Text = "Connected to Z-Wave plugin, name=" & plugin.Name
            End If
            label1.text = "HomeSeer Ver: " & hs.version
            Dim EN As Scheduler.Classes.clsDeviceEnumeration
            Dim dv As Scheduler.Classes.DeviceClass
            EN = hs.GetDeviceEnumerator
            Do
                dv = EN.GetNext
                If dv Is Nothing Then Continue Do
            Loop Until EN.Finished
        end sub
        Sub ButSpeak_Click(sender As Object, e As EventArgs)
            hs.speak(txtspeak.text,false,"")
            Do
                dv = EN.GetNext
            '    hs.WriteLog("SAMPLE", "Found device from aspx: " & dv.Name(Nothing))
            '    If dv.Interface(Nothing) IsNot Nothing Then
             '       If dv.Interface(Nothing).Trim = "Sample Plugin" Then
            '        End If
            '    End If
        End Sub
        Protected Sub Button1_Click(ByVal sender As Object, ByVal e As System.EventArgs)
            'hs.ExecX10("q7", "on")
        End Sub
        Protected Sub Button2_Click(ByVal sender As Object, ByVal e As System.EventArgs)
            'hs.ExecX10("q7", "off")
        End Sub
        Private Function GetHeadContent() As String
            Try
                Return hs.GetPageHeader("", "Test Page", "", "", False, False, True, False, False)
            Catch ex As Exception
            End Try
            Return ""
        End Function
        Private Function GetBodyContent() As String
            Try
                Return hs.GetPageHeader("", "Test Page", "", "", False, True, False, True, False)
            End Try
            Return ""
        End Function
    </script>
    <html>
    <head runat="server">
    <%response.write(GetHeadContent())%>
    </head>
    <body>
    <% response.write(GetBodyContent()) %>
        <form runat="server">
            <p>
                <asp:Label id="Label1" runat="server" width="210px">Label</asp:Label>
            </p>
            <p>
                <asp:Label id="Label2" runat="server" width="400px">Label</asp:Label>
            </p>
            <p>
            </p>
            <p>
                <asp:Button id="ButSpeak" onclick="ButSpeak_Click" runat="server" Text="Speak"></asp:Button>
                <asp:TextBox id="TxtSpeak" runat="server"></asp:TextBox>
            </p>
            <p>
                <asp:Button ID="Button1" runat="server" OnClick="Button1_Click" Text="Light On" />
            </p>
            <p>
                <asp:Button ID="Button2" runat="server" OnClick="Button2_Click" Text="Light Off" />&nbsp;</p>
            <!-- Insert content here -->
        </form>
    </body>
    </html>
    tenholde
      This is for test.aspx I guess? No, I 'm after localhost/test, in the developers webinar 21 Dec 2012 the HS developer promiced to post the source code for the page to show how to use clsJQuery controls
      Click image for larger version  Name:	2018-11-15 (1).png Views:	1 Size:	61.0 KB ID:	1259541
        To be honest, the sample plugin provides more jQuery info than the sample page. Once you get things loaded into Visual Studio, the IntelliSense helps as well.
        68 Z-Wave Nodes, 174 Events, 326 Devices
          'Test' page has a lot of controls - would be nice to see the source.
