How do you debug a multiple instance plugin
  • How do you debug a multiple instance plugin
    specifically i would like to debug the second instance
    I'm using VS15 with VB.net
    i have the following plugin calls:
    Public Function SupportsMultipleInstancesSingleEXE() As Boolean Implements HomeSeerAPI.IPlugInAPI.SupportsMultipleInstancesSingleEXE
    Return False ' True requires the plugin to manage the the instances
    End Function
    Public Function SupportsMultipleInstances() As Boolean Implements HomeSeerAPI.IPlugInAPI.SupportsMultipleInstances
    Return True
    End Function
    Mark
    HS3 Pro 3.0.0.534
    I believe you have to attach to the process, so if you want to debug say startup you'll need to put in a sleep loop (usually in a debug build) so you have a chance to connect to it.
      Thanks for the response.
      maybe i'm missing something. With the settings i have above, aren't all the instances running out of the same exe? so i shouldn't have to connect to anything if i start the plugin via vs15 and just add instances via the plugin manage page
      Mark
      HS3 Pro 3.0.0.534
